Torch tip?
on a tee joint you showed the torch tip touching the work piece,does this cause any problems
audreyobscura7 months ago
Oh yeah, that was just to demonstrate how the wire should be feeding into your weld puddle. (Its hard to photograph a weld puddle with regular DSLRs because the puddle is so bright :P) You want your wire feed tip to be aimed 45° into the joint so that you are penetrating the intersection of the materials properly.
