Touch Controlled Resistor?
answer
Answer it!
There is a chip, don't remember what it is called, but you input a binary coded number from 1-255 and it sets the resistance based on the number input. It works as a digital vol. control.
You can build a touch switch that will vari the resistance based on how hard you press. I've don't this using static control foam that chips are shipped on. Connect this to an a/d chip. That's an analog to digital chip. It takes an analog value and turns it into a digital number. Then feed that number into the resistor chip.
