Transistor NAND Gate does not completely work.?
I have been trying out some logic gates using transistors and I am confused already. I have built a NAND gate using 3 2n3904 BJT's. The resistor values are aprox the values in the schematic. The Diodes are 1N4003.
Vcc is 5v (~4.9v)
The schematic can be found here https://www.instructables.com/id/Digital-Logic-Gates-Just-Using-Transistors/
I have everything hooked up like the schematic shows. The issue I am having is that it is not working as I would expect a nand gate to work.
The truth table shows that if A and B are both Low then C is High.
If A is High and B is Low then C is High.
If A and B are both High then C is Low
Here is what really happens.
A Low: B Low: C High
A Low: B High : C High
A High: B Low : C Low (but still ON just very very dim) <=Shouldn't this still be a High state?
A High: B High: C Low
Does any one have any ideas as to why it is behaving like this. I have rebuilt this circuit about a dozen times now making sure I have things correct. I am stumped.
lemonie5 years ago
If you've rebuilt it twice and it didn't work, why try the same thing another 10 times before giving up?
There isn't a C in the schematic, I guess this means the LED?
I also guess that you're using a bad (and untested) circuit, look for another.
E.g. http://www.dummies.com/how-to/content/electronics-projects-how-to-create-a-transistor-na.html
L
