Transistor vocoder?
11
answers
Answer it!
If you want a low-budget vocoder-like effect, I'd suggest looking at the "talking guitar" effects. These used a speaker firing through a tube into the person's mouth. That doesn't get directly combined with their voide, but it uses the resonances of the vocal cavity to shape the instrument's sound. Of course you then pick up the results with a microphone for recording or amplification, generally the same mike you were using to pick up the singer's voice.
Basically, ring mod can be thought of as generating side tones -- the sum and difference of (each of) the frequencies on the carrier vs. those of the modulation.
The result may not be particularly musical, though mixing the source material back into it might help.
Since it's cheap and easy, you could try it and see if you like it. Though personally I always lean toward an op-amp based circuit for audio processing rather than a single transistor, since that avoids having to deal with all the details like biasing the signal so it's in the linear region of the transistor's response curve to avoid distortions you didn't intend to produce.
Vocoder simply can't be done that simply. Period.
