Turbocharger to generator conversion?
Hey, I was just wondering, could we turn a turbocharger into a generator that would produce electricity as water flows into one gate and out the other?  Similar to a hydroelectric generator using the mechanical energy of flowing water through a turbine to produce electricity.
Apr 23, 2012. 9:49 AMrickharris says:
A lot depends on your water source - A turbo expects a high speed flow of gas so it isn't very big.
Water turbines tend to be quite big to extract maximum energy from a large volume of water rather than a fast flow.
You might be better off with a water wheel and gear up the output to drive a generator. The wheel give you slow rotation at huge torque.
Apr 23, 2012. 1:20 PMsteveastrouk says:
Look at "impulse turbines" and the "Pelton wheel" - both high pressure low flow concepts.
Apr 23, 2012. 12:12 PMlemonie says:
Yes, but you'd need quite a lot of water flowing through it and at a fair pressure / head.
What have you got?
L
Apr 23, 2012. 9:51 AMiceng says:
A turbocharger has special blade design made to react to a hot gas
and rotate very very fast.
Water wheels are designed to be turned by a liquid and because water
density is 62.4 lb/ft3 that is 815 times as dense as air 0.0765 lb/ft3.
The blade shape of a gas turbine cannot accept the strength and energy imparted by a liquid. It will turn in a sloshing type motion
and stop at any mechanical load where the delicate gas blades
may brake off....
Further a gas turbine electric generator would be a very high speed
and output frequency type compared to a water wheel generator.
A
Apr 23, 2012. 8:57 AMbwrussell says:
In theory you would just need to swap the compressor for a shaft connected to a generator. The turbocharger would be like the blades on a windmill, you still need the actual generator.
In practice it all depends on how well a water stream will turn the blades, it should be but when you're using something for something other then it's intended purpose weird things can happen.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
