loading
Ultra-simple low pass audio filter?
Is there a way to create an ultra-simple low pass filter? Will not be using it for subwoofer, but to split audio and boost the power for audio-synced leds. Is a split at about 15-200 hz any good? or should it be higher/lower. Mostly looking for bass guitar and some drum to go in this area. I am totally non-audio knowleged, and am beginning my circuit building skills, so yes, i need lots of help. Can i hook this in parallel to speakers and will it not affect sound quality? can i use a separate audio (no op-amp) amp to boost power to leds? (such as a .5w amp to leds that consume less than .5w?) or should i find an op-amp. Could i just put the filter on and hook leds up in parallel w/out sound loss? I am getting totally lost. I know this is a LOT to ask of you, but your answers to my previous questions have been very helpful and are greatly appreciated. Thanks for putting up with me :) I wish i could figure this out better, but i am having a hard time. So far example no.1 on this link (about halfway down page) seems to look pretty good. Thanks!!!!
http://www.electronics-tutorials.ws/filter/filter_2.html
AN RC filter would work just fine as the simple LP filter you want. Making filters SHARPER, needs more parts, but a first order RC network.
For the work involved, I'd put an amp in personally.
Steve
astroboy907 (author)  steveastrouk6 years ago
would this work?
http://www.muzique.com/schem/filter.htm
put in a 3k ohm resistor and a .33uf cap to get a corner frequency of 160.8hz, would that work??
Try it !
thx!
k.. will do
66626665 years ago
Graphic Equalizer Filter can be found at http://www.sparkfun.com/products/10468
66626665 years ago
I'm using graphic equalizer filter msgeq7 that separates audio into seven separate outputs. It's a simple plug and play operation.
astroboy907 (author)  66626665 years ago
sounds awesome!! do you have a link to what you are using or is it custom?
astroboy907 (author) 6 years ago
im sorry, about a third down the page, not half. :)
