Unable to program an Arduino micro. Any ideas on how to fix this?
I've been working on a project for some time now, and I plan to embed an arduino micro into it. As such, I just went to do a dry run of the setup with the micro before I started putting it all together. And failed miserably.
Few things to get out of the way:
-It is an off-brand, but it does have the ATMega 328 at it's core.
-My computer (win7) does recognize it, although it's as a USB Serial Port (com6) and not an arduino micro
-I am using the 1.0.5 IDE
-My PC will only see the micro as a USB Serial port on one of my USB ports. On the others, it sees it as a USB hub (and a failed one at that)
-I have tried to manually update the drivers (by pointing windows to the driver folder): it will only say that the correct driver is installed (either the Serial Port or USB Hub) and refuse to go past that
-I also tried to manually assigning the driver via "I have the disc" only to have my PC blue-screen
-I have powercycled. Too many times to count.
-I have tried with another micro: same issue
-I have tried without anything connected shy of the USB cord and free hanging, to ensure nothing metal was touching it
-The IDE does have the correct setting (correct board selected and COM port)
-I've tried several sketch (mostly those from the "Example" section of the IDE) and each time I get the same error
-I have tried holding the on-board reset button while uploading, letting go just at the moment the IDE says "Uploading"
With what I hope is the obvious stuff covered (though chances are I did miss something stupid, and thats whats causing this) the error I get is as follows:
Binary sketch size: 5,190 bytes (of 28,672 byte maximum)
Found programmer: Id = "B<<g"; type =
         Software Version = . ; Hardware version = .
avrdude: error: buffered memory access not support. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
I als thought that maybe the bootloader was bad (I'm a tad of a noob to this, so I'm not 100% sure of the above error can be caused due to a poor bootlader) and tried to upload it. This pops up:
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
Any help would be greatly appreciated!
With the ATMega 328 you may need to select the Duemilanove board in the IDE. Are you sure the chip is not a fake? Are you sure it has the arduino boot loader on it already?
These kinds of problems are why it's best to buy the real thing instead of a cheap knockoff.
DoctorWoo (author)  mpilchfamily3 years ago
Your something awesome! That did that trick, and it's taking sketchs, no problems. Thank you so much!!
I'll try the Diemilonove board here in a moment. As for the chip: I don't know if it's a fake. It looks like the real thing, but thats as promising as a sticker. I'm also not sure the bootloader is on it. The LED does flash, so I would assume so. But I am unable to upload it even if it isn't on there.
And this I do know now. I had a friend who had a handful in a box of junk that I threw a few bucks his was for. So if they fail, now skin off my nose.
