Using 12VDC spotlight charger on LED's?
I have an old rechargable spotlight that I never use, so I figured I would use it for parts.  Could I use the charger 120VAC/12VDC to power some LED's, like if I wanted to make an under the counter light?
If so, would it be better to run the LEDs parallel or in series?  I was reading an instructable on beginning LED's and saw that series will divide the 12 volts to each LED (4 LEDs at 3 volts each), and running parallel will send the entire 12 volts to each LED.  Would I use resistors even if I ran the LED's in a series?    If I ran the LED'S parallel, would the follow crude schematic be correct?
Picture of Using 12VDC spotlight charger on LED's?
You can't run them in parallel.
Its not good to run them without a resistor, or some current control. Better have three LEDS in each string, with a 150 Ohm resistor on the string.  You can have lots of strings.
Steve
Yes.
pennsteve (author)  steveastrouk7 years ago
Was that a yes to my new schematic?  I seem to be havig problems loading another photo, so I deleted my reply. sorry
You've got the right idea.
What colour of LEDs are you using ?
Steve
I went to radio shack and got 2 white and 2 red.  Not sure what I am using yet.  I know that from now on I think I'll send to Honk Kong for the LED's, unless I can find them cheaper around here, which I doubt. lol
pennsteve (author)  pennsteve7 years ago
Ok, another question.  If I run a string of three 3Volt, do I use 9 volts (3 LEDS at 3 volts each) in the calculation to find the resistor I need, or just 3 volts?
You ADD the "forward" voltages of your LEDs together - so, say you have two that drop 1.2V and 1 that drops 3 v, you have a total of 2.4+3 or 5.4V in your LED string.
Take the supply voltage (ideally at least a couple of  volts more than the forward drop - so here, I'd like to see a supply of at least 7V.
Take the ideal current through the LEDS, lets say for the sake of example, 20mA and then calculate (supply volts - diode drop)/ ideal current - this gives you the series resistor you need.
( 7-5.4)/0.02 = 80 Ohms.
Steve
