loading
Voltage Doubler Caps, what voltage should I use for 30-40v wind gen?
Voltage Doubler Caps, what voltage should I use for 30-40v wind gen?and what difference it makes if milifarad bigger or smaller or mixed?
Why do you want to double the o/p volts ? The size of the caps affects the output impedance of the doubler, but you will not of course be getting any more energy from it.
Steve
celalboz (author)  steveastrouk5 years ago
Thank you for reply,
I was going to up the voltage from a stepper to 18v to my diy regulator down to 13.8v for the sla charging (albeit I am aware when you voltage double; it does that by the expense of the amper) but it is ok because this stepper puts out 200ma and I need half that for my charging as long is voltage is correct.
Question is:
four 2200mf 25v caps vs 300mf 300v caps which will be better?
I have 50 each kind in my arsenal..
thanks
