loading
WHAT COULD I DO WITH A LAWN MOWER ENGINE?
i have a lawn mower engine and dont what to do with it thats fun
Aron3135 years ago
Make another lawn motor. HAHA! What hp is the mower. If its not enough power it wouldnt be fun to use it in a go kart.
acidbass7 years ago
 go kart, motor cycle, flame throwing go kart,
Tombini7 years ago
- Make a Go Kart - Irritate your neighbors - Rev it loudly - turn it on in an inclosed room and suffocate on carbon monoxide - Sell it - Throw it at someone
rickharris7 years ago
Hover craft but you will need a propeller. make a ride on lawn mower make a 12 volt emergency generator from the motor and a car alternator
Phil B7 years ago
Make a low speed go-kart. I am assuming your engine is about 3.5 HP. It is probably vertical shaft. A horizontal shaft engine is easier to use on a couple of counts. The vertical shaft engine depends on the mower blade to serve part of the function of a flywheel and will not run without a flywheel of some sort. The flywheel could be some sort of balanced flat plate mounted to the engine shaft. Let the flat plate rest on a pulley with a rubber tire. Make the engine mount so the flywheel's center can slide inward or outward on top of the tire on the pulley for a transmission with infinite gear ratios. Beyond something to ride, the other applications for a mower engine are mostly practical, like powering a pump or a generator.
