WHICH ONE?
TODAY I GOT A CIRCUIT THAT'S A USB BLINKER CIRCUIT I FOUND THE TRANSISTORS ARE NAMED LIKE THIS " 2x NPN General Purpose Transistor (Q1, Q2) " I DON'T KNOW WHICH TRANSISTOR I WOULD USE TO MAKE THIS CAN ANYBODY ELABORATE??
Oct 8, 2012. 9:22 AMmpilchfamily says:
Something that basic isn't going to need anything special so i'm sure a 2N3804, 2N2222 or BC547 will do the trick. You can get a pack of general purpose NPN transistors at Radio Shack for a few bucks.
BTW there is no need to yell out your question. (all caps comes across as yelling)
Oct 9, 2012. 10:46 PMkelseymh says:
USE THE CHEAPEST ONE! AND THEN USE THE MONEY YOU SAVE TO BUY A NEW KEYBOARD WITH A WORKING CAPS-LOCK KEY!!!1!!!1
Oct 9, 2012. 11:51 PMkelseymh says:
:-) Since MPilch had already given you a decent answer (i.e., a low precision application doesn't usually require a special-purpose component), it didn't make a lot of sense for me to repeat it.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
