loading
WHY DOES THE HORN ON MY 1994 FORD CROWN VICTORIA COME ON WHEN I TURN OFF THE KEY?
Re-design7 years ago
Probably there is a short in the wiring somewhere.  But there are two other possibilities.
1.  There are several power relays that turn off when the key is turned off, and if one of them has a short in the wiring this might cause the horn to honk.  It could have just as easily turned on the dome light, the starter etc.  I just happened to be the horn.
2.  The way cars are wired now is that some wires are used for multiple things by using diodes.  If a diode has shorted then it is not resisting the current anymore and could allow current to flow when the key is turned off.
If I were starting to look for the answer, I would pull the ignition switch and check inside the steering col. to see if any of the wires there are shorting against the ignition switch connections.
jenabot3 years ago
problem in wiring
Because it's a Ford.
Putzer8 years ago
Does it do it when the engine is turned off, or only when the key is turned past a certain point regardless of engine status?
UC FATHER TIME (author)  Putzer8 years ago
Only when the key is off
 like, all the time? is your car sitting in your driveway/garage/shipping container with the horn constantly blasting?
BeanGolem8 years ago
It's thanking you for conserving fuel.
