loading
WHY IS MY MOTOR GOIN IN REVERSE, I HAV THE BATTERY CONNECTED CORRECTLY, WHY IS IT MOVIG IN REVERSE?
TSC6 years ago
Just switch the wires and it should go the way you want it.
wobbler6 years ago
The battery may be connected correctly, but did you reverse the motor connections by mistake? The battery will need to be connected the correct way for the electronics to work, but the motor shouldn't matter, it will simple go in reverse if you've connected it wrongly. Try reversing the motor connections but leave the battery connections alone.
Plasmana6 years ago
You either have the battery connected the wrong way round, or the motor improperly installed. If your motor electronically controlled, then the chip may be fried.
rickharris6 years ago
Think!
seandogue6 years ago
+1, lol, +1, +1, +1 for the answers below
in06khattab6 years ago
swap the battery round or connections from bettery!
kelseymh6 years ago
The caps-lock key on your keyboard is a wireless reverse switch for your motor. Turn off the caps lock, disconnect and reconnect your motor, and it should work perfectly.
That's because today is Backwards Day!
lemonie6 years ago
In the classic sci-fi vein: "reverse the polarity", i.e. swap the battery connections.
L
Re-design6 years ago
If you truly have the battery connected properly then
You have it in reverse gear,
There is a reversing switch that is in the reverse position,
Your rechargeable batteries have taken on a reverse charge,
You are running an ac motor off an inverter and the starting capacitor is installed backwards,
There has been a cataclysmic event that has reversed the poles of all magnets in the world,
OR,
You don't really have the batteries hooked up properly.
