3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Well I bought this item...?
 And it says disappearing ink on the label and the tip of it has some foam on it to write with but when I put it on paper it goes on clear and leaves clear.It is a bottle with a foam covered tip. I was trying to find any way to get the ink back but there was no instructions for it and no name.
Nov 12, 2009. 8:37 AMGoodhart says:
Most  disappearing inks,  at least the kind that are used for jokes (spill it on someone's expensive WHITE blouse and watch them go BONKERS until it vanishes) are not really "inks" (too thin) but a solution that turns clear after a period of time exposured to AIR.
IF this is what you bought, it has been exposed already and has gone BAD.  Return it ASAP so no one thinks you did it on purpose.
Apr 12, 2010. 4:30 PMGoodhart says:
If it was the type that disappears when exposed to air, yeah.   Sorry.
Nov 12, 2009. 5:38 AMKoosie says:
Wouldn't it perhaps remove or "disappear" ink from a normal pen.  Kinda like an eraser for a pencil.
I don't know, just thinking aloud.
Nov 11, 2009. 7:29 PMorksecurity says:
I'd say it disappeared before you bought it. Take it back to whoever you got it from...
Nov 11, 2009. 6:39 PMacidbass says:
invisible ink shows up under heat and lemon juice or blacklight or on a certain type of paper
Nov 11, 2009. 6:11 PMkillerjackalope says:
You mean get it back as in see the now disappeared ink?
Eh it may be UV ink, a blacklight would make it appear...
Could be activated by another agent that they've not included...
Sometimes it's heat, you can make your own with lemon juice or some such, I'll look in to that but it's heat that shows it...
Other than that, look at similar products for ideas, try what they use, eventually you'll find something...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
