What Do These Mean?
I'm trying to construct an entry for the Wicked Lasers contest, however I keep on finding the same letters on several diagrams...
Can anyone tell me what the G, S and D stand for?
Mar 20, 2011. 11:21 AMsteveastrouk says:
GATE
SOURCE
DRAIN
Mar 20, 2011. 12:57 PMseandogue says:
The device is a Field Effect Transistor, a type of transistor that uses an electric field to change the impedance from drain to source from near-infinite to near zero. They can be used as switches and amplifiers, amongst other uses.
A voltage is applied to the Gate terminal to determine the state of the drain/source impedance.
IMO, you should google it or go to wikipedia for a lengthy answer.
Mar 20, 2011. 1:49 PMsteveastrouk says:
If you're building from an existing diagram, just follow it. Like Sean says, its a MOSFET, a field effect transistor, how it works is tricky to understand.
Mar 20, 2011. 3:59 PM7654321 says:
A current at the gate makes current flow from the drain to the source (yes the names sound backwards)
Mar 21, 2011. 5:47 AMseandogue says:
The gate voltage (not current) does not make anything happen other than to reduce the impedance of the semiconductor junction.
Mar 21, 2011. 1:47 AMsteveastrouk says:
NO There is no steady gate "current" MosFETs are voltage driven at the control, unlike BJTs.
Steve
Mar 21, 2011. 5:50 AMseandogue says:
right.
In fact, for all intents and purposes, (and aside from hair-splitting) there isn't any current at the gate, steady or otherwise.
FETs are voltage controlled devices.
A BJT however, can be (in some ways) modeled after a venturi. Flow (literal) from the Base to emitter is necessary to switch the collector/emitter flow. And in fact it is directly proportional to that flow by the Hfe
Mar 21, 2011. 7:30 AMsteveastrouk says:
Me ? Split hairs ?
I WAS thinking of gate capacitance charging.
Steve
Mar 21, 2011. 8:35 AMseandogue says:
oops. NO I didn't mean you were splitting hairs. was just trying to imply that yeah...there may be current, but it's tiny and simply a parasitic rather than a causal like in a BJT.
Just trying to keep my comment in the thread rather than making it possibly non-sequitur by posting separately...
Mar 21, 2011. 9:45 AMsteveastrouk says:
Hehe
Its alright, I am a champion hair-splitter ;-)
Steve
Mar 21, 2011. 11:16 AMseandogue says:
HA! I was right then. you woulda caught me on it if I hadn't added that qualification. NYAH! ;-)
(as if I'm anyone to talk)
Mar 21, 2011. 11:25 AMsteveastrouk says:
He he he
Mar 20, 2011. 4:33 PM7654321 says:
Actually I think it can go both ways, nevermind
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
