What are hanger bolts for?
Jun 27, 2010. 1:29 AMKiteman says:
Answer number one:
The pointy end screws into wood (use a spanner on the squared section in the middle), then you fasten something to the blunt end with an ordinary nut.
In this example, the bolt is being used to stiffen the corner of a wooden frame by pulling the metal plate into the timber joint.
Answer number two:
They are part of the gear system of a bicycle.
Jun 27, 2010. 11:26 AMlemonie says:
Nothing to do with climbing then...?
L
Jun 27, 2010. 7:48 PMaeray says:
As far as rock climbing equipment goes (in the US at least) "bolts" are the (permanent) mechanical fasteners inserted into drilled holes in the rock and "hangers" are the perforated metal plates semi-permanently attached to the bolts that allow temporary gear (usually carabiners) to be attached to.
Jun 28, 2010. 10:39 AMlemonie says:
The question is a bit vague, thanks for the info on those things.
L
Jun 27, 2010. 7:57 PMaeray says:
Hangar bolts (that resemble the threaded portion of a machine screw attached in-line to the threaded portion of a wood screw or lag bolt with no heads in evidence) are most commonly used in the light commercial and residential construction industry to attach wall-mounted porcelain plumbing fixtures (i.e. toilets, sinks, and urinals) to wooden framing. The lag or screw part is driven into the wooden framing using a pair of vice-grips or channel-locks and then the fixture is hung on the bolts through pre-cast holes and secured with nuts and washers.
Jun 27, 2010. 11:12 AMonrust says:
2 things here: 1.What you are hanging. 2. What you are securing the said hanging item into or on.
Jun 27, 2010. 1:37 AMfrollard says:
"Hanger bolts are ideal for overhead applications, such as suspending electrical wiring or sheet metal from wooden structures." answer from google. It's wood threaded on one side and metal (nut) threaded on the other side such that you can drive it into the wood, then bolt something to the wood at varying heights. http://www.usifaz.com/Web%20Site%20Pics/Screws/Hanger%20Bolt.gif
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
