loading
What are the specs of microwave transformer?
I am trying to build an AC arc welder from transformers. I need to know how many amps, volts and watts a normal microwave transformer outputs because i am trying to use different transformers, as i don't have two microwaves on hand. -Thank You
Wesley6667 years ago
Depends on the transformer. Usually they have one primary input and two outputs. One output is either 2000vac ( they usually are) unless you have a really old one like I do and it puts out 12vac at 60amps. The secondary is 12v at low amps for running everything else (timer and what not) but if you have one that generates 2000v turn it around and you will get 12v 60amps out of the input. This is tricky though as sometimes the transformer will just blow the breaker.
Mr.l39 months ago
Also, I nearly got electrocuted from deadly dangerous current high voltage of microwave oven transformer. I got it on utube.
Mr.l39 months ago
microwave oven transformer has 2200v output. Filament is 3v. 30amps I think. 900 watts to 1100 watts. I have three transformer I took apart of 8 microwaves. You can make a 200v or 240v out of two transformer. One transformer connect 2kv to two transformer secondaries. Then primary out is 200 or 240v. Works for every 120v to 240v electronics. Thank you for reading. -Trent Basden
arunaravind11 months ago
i have GAl-800E-3 model transformer.if it is used for make spot welding machine?
eric m7 years ago
squirt85007 years ago
How many pins are the on the transformer? If you have a Multimeter try to see what pins connect to the other pins and if they do connect check how many ohms each connection is, the connection with less ohms will probably be the one that you connect to the wall and the connection with more ohms one will probably be the one connected to the welder.
