What can I do to prevent lightning damage with this device?
I want to place it about thirty-forty feet above the ground, between two large trees. This would be above the power lines in my area, and also above most everything else besides the trees themselves. This seems to pose a significant risk of having lightning strike it. I don't want to have to put it up and take it down every time there is a storm (nor am I always here when there is one). Is there any way to make this safe from a lightning strike?
P.S. I know this works--one of my friends works for Honeywell and, when asked whether or not this was true, he explained that they have had conferences, lectures, etc. about the problem of static buildup on power lines. My line length would be around 200-300 feet long, which is certainly not anywhere near the miles that many HV hydroelectric lines in my area run for, but it is still quite long.
15
answers
Answer it!
L
The static business I'd expect to be based on some design that is proven, given how long people have known about these phenomena. Can you point to something that does collect a worthwhile amount of charge?
L
L
I'm not too far off Emley Moor, but with the inverse-square law, I'd be pleased to light a LED...
L
Secondly, I was thinking of possibly some kind of lightning detector (perhaps similar to that of Benjamin Franklin) which would trigger a solenoid to physically move the end of the wire that would normally be charging the battery to a ground rod. Anyone have any ideas on how to make a good lightning detector?
EVEN if you could realistically capture the megavolts and megaamps of a lightning discharge, which is the limiting case of this static idea, the actual amount of ENERGY is not that high. I've seen figures of around 1/2 kWhr from a single strike. - 100W for 5 hours.
Steve
. Any amateur radio (ham) site will have lots of info on how to protect (as best as one can) antennas and the equipment attached to them. The ARRL is an excellent ham site.
. Most lightning protection that is designed for close hits relies on a spark gap or similar arrangement that is dependent on high voltage to jump a gap. Your static harvesting project will already be producing a high voltage on your antenna before any lightning hit occurs. That may be a problem.
. Provide an easier target. Electricity is lazy and will take the path of least resistance.
There's the clue. You ain't going to extract significant real power from a static discharge.
Steve
