What could I use to amplify 6v DC to run 8 LEDS?
Firstly, I am sorry for my lack of knowledge on the subject of electronics. I have an output voltage of 6 DC volts that I would like to amplify to run 8 LEDs in series. What I am trying to do is use this colour organ to run more than just four LEDs per range of music. I need it to run eight. I was wondering if there is any way to do so, that would be relatively simple. Would buying this work? I don't mind buying anything extra in order to do this, so please, help!
frollard5 years ago
just replace the single led in your example organ with a transistor that switches on/off MORE voltage
...or...
run more leds in parallel if the chip will handle the current draw (an led is 10-25mA each)
Metalio (author)  frollard5 years ago
Ah, thanks. I guess it was really that simple then. I was under the impression that I would have to make it more complicated.
You can either increase the supply voltage, or just add two more parallel chains of 2 on your existing transistors.
Looking at the components used, you can probably increase the supply voltage to allow you to drive the LEDs with no problem.
Steve
lemonie5 years ago
Do as frollard suggests: use transistors.
L
