What do i add to my alcohol fuel for my flamethrower, to make the flames brighter?
Hi Im working on a flamethrower which is turning out pretty well, the only issue is, since im using alcohol as the fuel, the flames are pretty much invisible, i was wondering what i could add to increase the carbon content. Normally ide experiment with adding a little gasoline, or diesel to it, but i have to be careful with my pump, its made from either ABS or PLA, and for some reason everyone on ebay who sells them are very sketchy, ive bought 4 in the past and only the last one ever arrived.
Anyway, what can i add to my fuel to make its flame more visible?
Fortunately my flamethrower does not leak at all so its safe to move up from alcohol to something with a higher burning temp.
What can i add that will not dissolve the plastic, increase flame brightness, and not increase the burn temp too much.
Before hydrocarbons, are there any salts or chemicals i can dissolve into the alcohol to do this? i beleive i can dilute the alcohol a bit with water so it will take sodium, but will that have any significant effect?
The sun is pretty bright here so alcohol flames are invisible, gasoline flames however are very visible in contrast.
Thanks
Jan 5, 2013. 10:20 PMrickharris says:
Your playing with fire here and making something that in most countries is illegal. I won't even go into the danger
Jan 6, 2013. 12:57 AMrickharris says:
Ah not the type of flame thrower I was thinking about - A weed eater is just a big blow lamp. Although I have no experience of using or building a flame thrower I do know that putting paraffin or diesel into a flame makes it yellow.
Many chemical salts will colour flames:
Copper = green potassium - red Cobalt - Blue
From Wukipedia
As  Arsenic  Blue
B  Boron  Bright green
Ba  Barium  Pale/Apple green
Ca  Calcium  Brick red
Cs  Caesium  Blue-Violet
Cu(I)  Copper(I)  Bluish-green
Cu(II)  Copper(II) (non-halide)  Green  Flame test on copper sulfate
Cu(II)  Copper(II) (halide)  Blue-green
Fe  Iron  Gold
In  Indium  Blue
K  Potassium  Lilac
Li  Lithium  Red
Mn (II)  Manganese (II)  Yellowish green
Mo  Molybdenum  Yellowish green
Na  Sodium  Intense yellow
P  Phosphorus  Pale bluish green
Pb  Lead  Blue/White
Ra  Radium  Crimson red
Rb  Rubidium  Red-violet
Sb  Antimony  Pale green
Se  Selenium  Azure blue
Sr  Strontium  Crimson
Te  Tellurium  Pale green
Tl  Thallium  Pure green
Zn  Zinc  Colorless (sometimes reported as bluish-green)
Jan 6, 2013. 12:59 AMrickharris says:
NOTE: Information only.
What you do with that information is YOUR responsibility in no way am I encouraging you to build. use or even consider a flame thrower in any form or option.
Jan 6, 2013. 6:48 AMrickharris says:
Not really - sorry outside my area of expertise at this point..
What d you use it for?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
