What does a "Q Multiplier" do?
11
answers
Answer it!
Looking a the schematic, the signal is passed directly into an LCR filter. From there, NFB is used to create the active filter.
I'm not sure there's even an output, it appears to hook directly to the signal path; the unwanted frequencies are probably fed back into the coax cable, 180 degrees out of phase. I'm not certain the miller capacitance matters, especially if it's connected to an IF transformer (as explained below.)
Couldn't find a manual, but this blurb is helpful:
First, it doesn't hook up to the antenna leads!The outer cover of the coax goes to ground (naturally). Thecenter of the coax goes to either the plate of the mixer tube orthe plate side of the IF transformer. Looking at the HE-10 schematicat the 'Bama site, the mixer tube is a 6BE6 and the plate is pin 5.Either connect there or find the pin on the IF transformer that iteventually goes to. Heath provided a template and RCA socket withthe kit for installation. You may want to add such a socket.
Otherwise, it has a 12ax7 (THE preamp tube for almost all guitar amps) and a working power supply. So you could make a tube preamp...
The Real McTube is an example of one such circuit. Only it uses the "trick" of a pair of back-to-back wallwarts to get the filament voltage, and isolation on the HV. You wouldn't need the trick, the transformer on the schematic is perfect for a preamp...
Regarding the value, I don't know.
Is it rare? Probably not. There are five for sale right now on ebay, and none seem to be really expensive. But to the right person, just about anything is valuable. So you probably could find a buyer.
L
