3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
What is a good magnet project?
I have a really strong magnet. Its a cylinder about 2cm high and 1cm diameter.
What should I build with it/use it for? (Its not excessively strong, just really strong.
Aug 3, 2010. 1:14 AMKiteman says:
Aug 3, 2010. 5:58 AMRe-design says:
Build a motor.
Aug 3, 2010. 12:10 AMJack A Lopez says:
Try dropping it through a length of copper pipe.
This is a fun trick, probably too simple to qualify as a "project", but definitely something you should try if you haven't seen it before.  The magnet induces eddy currents into the walls of the pipe, causing it to fall much more slowly than it would under the influence of gravity, and air resistance, alone.
Aug 3, 2010. 5:57 AMRe-design says:
Cool!
Aug 3, 2010. 5:07 AMJayefuu says:
This one's fun and new. You'd need a piece of metal for the other half since you only have one magnet.
Aug 3, 2010. 4:37 AMyokozuna says:
The guy over at SciToys has all the best projects, including for magnets.
Aug 2, 2010. 11:31 PMAndyGadget says:
Find a battery and some stiff copper wire and make a homopolar motor out of it.
They're great fun!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
