What is distinct square?
give me a description of what a distinct square is in geometry
Some context would help. If you could tell us where you read a statement about a "distinct square" or "distinct squares", and what it said, that might help.
If it is the plural, "distinct squares", it might mean just mean squares that are distinct, meaning different, from each other.
I found all kinds of weird stuff searching on this phrase.  This page:
http://mathworld.wolfram.com/SquareNumber.html
uses the phrase in this sentence:
"There are only 31 numbers that cannot be expressed as the sum of distinct squares: 2, 3, 6, 7, 8, 11, 12, 15, 18, 19, 22, 23, 24, 27, 28, 31, 32, 33, 43, 44, 47, 48, 60, 67, 72, 76, 92, 96, 108, 112, 128 (Sloane's A001422; Guy 1994; Savin 2000). "
For example I can write 6 = 22 + 12 + 12 = 4+ 1+1, and that's a sum of squares, but the squares in that sum are not all different from each other, i.e. not distinct.
Getting back to something that looks like geometry, I read here,
http://www2.stetson.edu/~efriedma/numbers.html
the statement:
"21 is the smallest number of distinct squares needed to tile a square."
And this page,
http://www.squaring.net/sq/ss/ss.html
seems to say the same thing. Plus it has a drawing of what that square tiled with 21 smaller squares looks like.
Xixfas (author) 5 years ago
Never mind I figured it out
rickharris5 years ago
As opposed to??? what.
I feel the google translator has fail at this point.
kelseymh5 years ago
Did you try asking your teacher?
canucksgirl5 years ago
Homework?
I'm guessing that the teacher is asking for you to show a square that is easily recognizable (or distinct). So in geometry, you could show a distinct square in a graph where corresponding horizontal and vertical measurements allow you to clearly see that all four sides are in fact equal. (Obviously, if they are not, you probably have a rectangle).
Kiteman5 years ago
It's probably drawn in a different coloured pencil, or slightly larger than the other squares.
