What is reverse osmosis water?
7
answers
Answer it!
Reverse osmosis, as clearly described in the article, is a process by which external pressure is used to drive water through a semipermeable membrane, leaving behind dissolved minerals or other "impurities."
Normal osmosis is a pressure gradient caused by differing concentrations of dissolved materials on either side of a membrane. Osmotic pressure will push more-pure water across the membrane into the more-dissolved side, diluting the latter.
There is absolutely nothing special about water purifiied by reverse osmosis. You could equally well purify water with a distillation column.
Having said that, the good Wiki articles themselves properly cite original sources for the information they present. What you, as a researcher, should be doing is going to those original sources, reading them, and then citing them in your paper.
- Who in the world is "we"? Are you an editor?
