What is the best E-bike Kit for me?
5
answers
Answer it!
Commonly hub motors are used - and can be found at many ebike retaillers, (google it)
a less common method is to use a motor geared to your front pedal crank - thus you can use the pedals with or without the motor, and the motor will be able to use your variable geared 'transmission' - more complex, but more customizable.
I was reading a site, last night - to calculate your battery usage. For heavy usage, no pedalling, high speed, expect to use 14-20 watt-hours per kilometer. Multiply by your trip distance to get total watt-hour capacity...then divide by your motor voltage to get the amp-hour rating of battery you'll need.
Example - 5km round trip, @ ~15watt-h/km = 65 watt hours. 24 volt motor/battery pack would need a capacity of about 3amp hours.
check us out at
www.Ampedbikes.com
PLS VIEW THE WEBSITES:
Http:// www.electricbicycle-conversionkit.com
Wattage: 251 - 350w Voltage: 36V Power Supply: Lithium Battery
Wheel Size: Other Motor: Brushless Certification: CE
Frame Material: Aluminum Alloy Foldable: Yes Max Speed: 30-50km/h
Range per Power: > 60 km
Packaging & Delivery
Packaging Detail: CTNS
Delivery Detail ONE WEEK
Specifications
electric bicycle conversion kit
12-28''wheel
350-1000w
CCC, CE, ROHS, ISO9001, EN15194
Let's make things better!
FOR EURPEAN MARKET
BATTERY MOTOR WHEEL WEIGHT
24v-10AH LIMN FRONT gear motor 100MM 150w-250w 12"-28"700C 13KG
24v-10AH LIMN FRONT gear motor (100MMwith DISK BREAK ADAPTER) 150w-250w 12"-28"700C 13KG
24v-10AH LIMN REAR gear motor 135mm+6 CLUSER 150w-250w 12"-28"700C 13KG
24v-10AH LIMN REAR gear motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 150w-250w 12"-28"700C 13KG
36v-10AH LIMN FRONT gear motor 100MM 150w-350w 12"-28"700C 16KG
36v-10AH LIMN FRONT gear motor (100MMwith DISK BREAK ADAPTER) 150w-350w 12"-28"700C 16KG
36v-10AH LIMN REAR gear motor 135mm+6 CLUSER 150w-350w 12"-28"700C 16KG
36v-10AH LIMN REAR gear motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 150w-350w 12"-28"700C 16KG
FOR USA MARKET
BATTERY MOTOR WHEEL
24v-10AH LIMN FRONT direct motor 100MM 200-350w 12"-28"700C 15KG
24v-10AH LIMN FRONT direct motor (100MMwith DISK BREAK ADAPTER) 200-350w 12"-28"700C 15KG
24v-10AH LIMN REAR direct motor 135mm+6 CLUSER 200-350w 12"-28"700C 15KG
24v-10AH LIMN REAR direct motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 200-350w 12"-28"700C 15KG
36v-10AH LIMN FRONT direct motor 100MM 250w-500w 12"-28"700C 18KG
36v-10AH LIMN FRONT direct motor (100MMwith DISK BREAK ADAPTER) 250w-500w 12"-28"700C 18KG
36v-10AH LIMN REAR direct motor 135mm+6 CLUSER 250w-500w 12"-28"700C 18KG
36v-10AH LIMN REAR direct motor (135mm+6 CLUSER with DISK BREAK ADAPTER) 250w-500w 12"-28"700C 18KG
LEAD ACID SYSTEM
24v-10AH system OTHER PARTS SAME CHOICE AI LI SYSTEM
In the state of california the law reads that the bike should be no more then 750W (1hp) that should go no more then 20mph on a flat surface.
Some motors are more power hungry vs others. Crystalyte motors are probably the most powerful on the market BMC Motors are pretty decent. Pedal assist only motors are lame (Bionx) . You want a BLDC motor, or you will turn around in a few months to end up buying another motor.
Expect to spend atleast 1k on a motor, Non SLA 10AH battery ,BMS and charge controler. With all that said. I'm very content with 500W motor and 10AH LION setup 20miles@20mph in the Silicon Valley.
Good luck.
