3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
What is the best way to grind glass, somewhat smooth?
Now before you rush to write down an answer let me tell you the details!
The chunk of glass is 28 inches wide by 28 inches long and 2.5 inches tall. Composed of 160 painstakingly cut strips of glass that have been glued together into a jumbo block. Now try as I might, when laminating things together of ever so slightly different size together you are going to get high and low spots - And yes, this would have been soooo much easier a job if I had smoothed out the rough edges before laminating - Pesky hind-sight. Unfortunately my planer doesn't seem to work so well on glass, who knew :) Anyway, I will post some pictures to give you an idea of what it is, that has to be ground down.
First off
• It does not have to be perfectly smooth
• A mottled surface would actually be appreciated
• It is not going to be a lens of any kind, all though light will be transmitted through it.
I have the following tools, but first - No I am not taking it 1700km to have it kilned. No, the local glass shop seems to have less tools then I do, at least in this scale.
• Angle grinders
• belt sanders
• orbital sanders - but really?
On the back side I used the angle grinder, with a metal grinding bit. Not to bad really all though the edges were taking a pounding. This was prior to applying resin and woven cloth, to give the glass a bit of tooth and reduce the high edges.
This is for an instructable I am working on.
May 16, 2011. 4:02 AMPrfesser says:
You'll have to decide if a ground surface is ok, or is a polished surface desired.  For a polished surface you'll probably need to go down to about 600 grit, then use cloth and some sort of polishing compound (rouge, tripoli, etc.)  A ground surface can end anywhere after 200 grit, depending on the coarseness that is ok.
Doing by hand with abrasive paper, even wet/dry paper, will take a loooong time and a lot of paper.  Telescope makers (I've done this multiple times) use powdered silicon carbide abrasive and water, with another piece of glass as the grinding surface or "tool".  That will take a long time too. :-(  We usually start with 80 or 60 grit; for a big (>10" dia) piece of glass we begin with 40 grit abrasive.
As has been said earlier, a diamond wheel is likely to be the fastest method.  If you can wet-grind it will probably go a bit faster and smoother. Several grits of diamond wheel will probably be necessary.
Good luck!
Aug 7, 2011. 1:33 PMalkaff says:
use fine sander 300/400grit and on corner use flat metal for scrabing edges.
May 30, 2011. 1:34 AMstatic says:
I forgot to mention that a portable belt sander might be easier to use than the rotatory tools. Depends what you own, and what it cost rent what you don't
May 30, 2011. 1:30 AMstatic says:
While not going to level the high spots an acetylene torch may help bring smother surface. Not sure if the adhesive you use would take the heat, but you mention (no) kiln, and that would be hotter I think. Amateur astronomers still grind their own mirrors, the techniques they use are similar to what other suggested here. An automotive machine shop might have a cylinder head resurfacer that could do the job, but they probably wold charge more than what it would be worth to you.
May 15, 2011. 7:47 AMseandogue says:
Emery cloth is what I've used in the past. As was noted by danandlisa7, 120 or higher girt is appropriate.
Although....Rimar2000 has the easiest method. I just suggested the emery cloth because I've used it and it worked pretty well, and you may not own an angle grinder (i don't )
May 14, 2011. 5:39 PMiceng says:
Yes...  Some hardware stores sell "Wet Sandpaper" a very rugged
backing type of sandpaper does not tear up when wet.
I put it into an orbital sander, water my target regularly and orbit.
A
May 14, 2011. 5:17 PMterribug says:
If you don't mind a somewhat frosted finish, you can take it to the local autoship and have it sandblasted. Don't know what it will doto your seams, but it will dull the edges for you.
May 14, 2011. 1:24 PMdanandlisa7 says:
Beltsander 120 grit to start keep it moving so that it doesn't get hot
May 14, 2011. 8:33 AMrimar2000 says:
I've seen glaziers working hard on glass with hand grinder, using sanding disks like those of the accompanying figures.
May 14, 2011. 12:29 PMrimar2000 says:
Come to Argentina to buy them, here they are very cheaper. Surely are lower quality too, but they work.
Look this link to flapper discs. You must divide the price into 4.10.
May 14, 2011. 6:51 AMorksecurity says:
... and when you get past the finest grinding disks for rough shaping, you may need to proceed to increasingly fine polishes, depending on just how clean an edge you want.
Thought: Planer might not work, but a sander might, if you can get the right sandpaper.
Another thought: Glass dust can be Bad Stuff. Use appropriate dust control, dust mask, eye protection...
May 14, 2011. 8:23 AMsteveastrouk says:
Work wet
May 14, 2011. 3:09 AMsteveastrouk says:
Diamond impregnated grinding disks - 3M make them, not cheap, but VERY rapid removal rates, usually used in an angle grinder. Nothing else is going to last.
May 14, 2011. 3:10 AMsteveastrouk says:
PS. Use WET so make sure your tools are either airpowered or fully protected.
May 13, 2011. 8:31 PMonrust says:
I've had good luck scoring glass and grinding the edges SLOWLY with a cut off wheel on a 4" grinder. It will still give you white edges but it will be smother than a metal grinding bit. Can you make a small one to practice on?
May 13, 2011. 8:04 PMiceng says:
Use wet sandpaper a good smooth glass is accomplished with
600 grit wet sandpaper.
So you want to start with about 300 grit or less.
I have seen your work, you don't need more details.
It's slow work.
A
May 13, 2011. 8:18 PMfrollard says:
+1. Angle grinder to get the BIG stuff off, 300 grit on a WET angle grinder, then work your way up.
(@ author, great project!)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
