3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
What is the best way to restore this glued together box?
I found an art box at a thrift store. From the logo and wood, I'm guessing it's from the 50's or earlier.  The finish isn't plastic.
The joints are loose and the top piece is coming away from the sides of the lid.   What are the steps for putting it back together?  Gluing and clamping comes to mind, but how does one get the glue into the cracks?
The partitions are glued in. The partition spaces aren't ideal. Is there a fairly easy way to un-glue them so they could be rearranged?
Apr 19, 2011. 11:23 PMaeray says:
I get syringes and needles from the local veterinarians. It helps if you have an ongoing relationship with them so that they don't think your some kind of crackhead who wants needled for some nefarious reason.
Apr 19, 2011. 11:25 PMaeray says:
And using a compressor and a "puffer" nozzle will blow glue into the tiniest crack or crevice.
Apr 20, 2011. 1:37 AMVyger says:
In many rural areas farm supply stores carry all kinds of vet supplies. I used syringes to re ink my printer for many years. Would have made interesting tattoos if anybody tried to use them for injecting anything.
Apr 20, 2011. 10:42 PMaeray says:
A puffer is just a air nozzle. A straw might work, but you might pass out. I'd try using "canned air" (like Dustoff) but you'll have to be careful not to freeze the glue.
As far as removing the old glue goes, you may have to experiment. What does the old glue look like? If it is translucent/clearish brown, it might be hide glue which can be removed with hot water, or just a heat gun, if you're lucky.
Apr 20, 2011. 10:45 PMaeray says:
Just slop the glue on the crack, and puff it in with the canned air. Don't "hose it down" full-force, just puff at it until the crack is full. And clamp it if possible. Blue painter's masking tape, liberally applied, makes a remarkably effective and cheap clamp for awkward parts and joints.
Apr 22, 2011. 7:23 AMaeray says:
Try using a small amount of warm water with a dash of vinegar. Or, a heat gun or maybe even a soldering iron, for small areas, although I haven't tried the last one. Remember, hide glue is the original hot glue, so once you get it melted, work fast.
Apr 23, 2011. 7:52 AMaeray says:
How did the re-glueing go?
Apr 18, 2011. 5:05 PMBurf says:
Go to a craft store and get a large bore glue injector. Use yellow carpenter's glue(PVA) and clamp or weight the pieces down until the glue dries.
Apr 18, 2011. 9:55 PMcaarntedd says:
+1. You need to force the glue into the gaps, clamp the joints together, and wipe off the excess glue that oozes out with a damp cloth before it dries. Nice box.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
