What is the code for the project consists of lcd with IRsensors with arduino uno project
What is the code for the project consists of lcd with IRsensors with arduino uno project it works at the expense of the number of cars that pass the street with an account number in an hour and one which looks like the work of the work of system accounting system
iceng9 months ago
Specs for IRsensors ?
What LCD, how many characters, how many lines, serial or parallel input ?
How do you avoid IR overload from the sun ?
Are what you need to program any microprocessor.....
مرادا (author)  iceng9 months ago
16*2 LCD...i need the program display in one line the number of targets..and display the number of targets per hour in second line ..and i use microcontroll(arduino)
I use the IRsensors show in picture below ...
thank for you
iceng مرادا9 months ago
Start to study this ible that points to all kinds of useful links
https://www.instructables.com/id/Intro-to-Arduino/
There is no exact code to do what you want, you need to use small examples to understand and with the new knowledge combine them.
You will also need to understand electronics of the components you are using !
iceng iceng9 months ago
Good a 16x2 LCD but you still do not know it expects +5v, ground with a serial signal line or 8 or 4 parallel lines... After you study the ible, hook up the LCD and print HELLO on the second line... Then ask another question and I will help you with the IR....
Remember to use the Best Answer button.
Downunder35m9 months ago
Either you used a very bad online translator or used too complex words for it.
Try with short and simple sentences.
What you posted makes no sense at all.
مرادا (author)  Downunder35m9 months ago
Thanks you
