3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
What is the easiest way to make a automotive bulb blink, similar to a strobe!?
The bulb in question is a automotive 12 volt GE 904 wedge bulb.  Other bulbs could be used of course as this would be a simple mod.  And, yes, i know you can just buy car strobe kits, but I am trying to utilize what I have access to.  Our local scrap yard, which has several dozen cars in it allows free picking, so.... Anyone recommend what out of a car circuit I would need
Aug 20, 2011. 2:07 PMrickharris says:
An incandescent bulb is probably too slow to heat up/cool down to make a very fast strobe you would be better off with an LED.
To make it flash look up 555 timer.
Aug 20, 2011. 3:00 PMsteveastrouk says:
+1
Aug 20, 2011. 6:10 PMNachoMahma says:
. +1
Aug 22, 2011. 3:07 AMvicvelcro says:
A turn signal relay or hazard relay would provide the delay you are looking for and it is not a capacitor.
These relays are designed to be used with 12v incandescent bulbs. If you decide to try an LED instead of your 904 bulb, I can not be certain the relay would work as expected (it may turn on but not flash an LED).
Aug 20, 2011. 8:41 PMiceng says:
An auto bulb into a strobe by mechanical means at the focal inversion point
meets your requirements.  Use any small DC motor like an air fan. . A
Aug 21, 2011. 9:58 AMrickharris says:
Good lateral thinking - I like it.
Aug 20, 2011. 1:14 PMonrust says:
A turn signal flasher. It may be to slow.....?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
