Another thought: 12V halogen lighting unit - people throw these out, and they're not that expensive anyway. Compare wattages on the compressor and what you find in the lighting-section (of wherever).
I have a couple of 12 volt wall adapters but they are rated in the milliamp range. My compressor is a cheap one from the auto parts store and simply plugs in a regular 12 volt outlet. I keep killing my car battery when I host an all day pneumatic cannon escapade.
I collect broken stereos and stuff, some of them have some good heavy power supplies. A car-battery charger might do itl for you (or a car-battery, but they're bloody-heavy). Looking for "cheap ones from the auto parts store", I get up to 10A. The trouble with these is they're designed to run off your battery, which as you know can supply a lot and run-down as it does so...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
L
What did you want to run off it?
L
L
L
