What is wrong with my carburetor?
AENL wisconsin motor 9.2 hp. 163e Zenith Carburetor. Everything has been rebuilt. I did most of the work myself. I started it for the first time, it fired right up. Then stopped after a minute. I noticed it was flooding...badly. fuel was leaking out of the carburetor by the intake. I then pulled the cord a couple more times and now it is leaking gas through the exhaust port. What happened? Float to high? I set it to the gauge provide by the carb kit. It was pretty close to right on. What next?
Apr 25, 2012. 10:29 AMQuercus austrina says:
+2 (1 each for iceng and Re-design)
Constant leaking of fuel like that is indicative of a float valve that is, in some way, stuck open. Shut off the fuel line, drain the fuel from the carb, disassemble and verify the correct operation of the float and needle valve along with any associated linkages.
Make sure that the needle/seat assembly is clear of foreign objects (iceng) and not damaged or bent (Re-design).
Make sure that the float assembly is not binding/is sitting correctly in the pivot slots of the carb housing (Re-design).
When you are checking, you can put fuel in the bowl to make sure that when the float is up at the correct height, it closes the needle all the way. If it is open at all, you will have fuel leaking out of the feed line [inlet] (which, even though it is below the bowl level, would allow fuel to flow through the intake manifold/fuel outlet because the fuel tank is higher than the carb - "gravity feed"). If you have it closed all the way, say by pushing it closed with your finger, and it still leaks, you'll need to replace the needle and seat.
As for the fuel coming out of the exhaust port, take out the spark plug, give the engine a few spins and let it sit that way for at least 10 minutes to give the extra fuel a chance to evaporate. When you put it all back together, don't forget to check the oil in the crankcase. If it has any smell of gasoline to it at all, drain and replace with fresh oil. Oil contaminated with gasoline is not good for the engine.
Qa
Apr 25, 2012. 10:54 AMQuercus austrina says:
While you are at it, have a look at this question to see if what Wesley666 found out might help you.
Qa
Apr 26, 2012. 10:19 AMQuercus austrina says:
To see if the float is good, put enough fuel into a plastic container to enable "floating" of the float. Place float in fuel. Does it float? If yes, continue on...
Push float below fuel level and hold there for about 10 minutes +-. Use something inert to hold it there, your fingers or hand is NOT a good idea. Take float out of fuel and give a quick dry off and see if there is any fuel inside the float. Shake and listen for any shloshing or "wet sounds" inside. If it is dry inside, it is good. Let us know what you find.
Are there any missing pickup tubes or anything in the carb? Airbleed needles that are loose? Anything that can let fuel go where it is not supposed to? I can't find a diagram of the carb, so I don't know the specifics, but all carbs work in very similar ways. If you have a link to the diagram, rebuild sheet, or other documentation, it would help greatly.
Qa
Apr 24, 2012. 9:45 PMiceng says:
Did you check the piston rings or cylinder wall for scratches.
How clean was your fuel ?
Dirt could lodge in the float pin causing your flooding problem.
A
Apr 25, 2012. 12:02 PMlemonie says:
Float for sure (or a proper-leak).
L
Apr 29, 2012. 11:30 PMlemonie says:
I'm glad that you fixed it, thanks for the explanation.
L
Apr 29, 2012. 9:40 PMQuercus austrina says:
Glad you solved the problem. Sometimes carbs can be a real pain when the replacement parts aren't quite right. I had a Rochester Quadrajet that I could only get parts for on-line. That thing was a right b**ch to get correct. I ended up using my knowledge of how a carb should work to get it running right - none of the settings in the rebuild kit directions or any other literature were right for it. But once it was set correctly, she really made that lil' V8 scream.
May your Wisconsin live a long and happy life with you.
Qa
Apr 25, 2012. 6:02 AMRe-design says:
The float pin or seat could be damaged. The float may be jammed when you put the car back together. Something is holding the float open allowing way too much gas into the intake.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
