What is wrong with my laptop battery?
I have a Dell Inspiron 1501 laptop. The battery is giving me issues. It only gets up to a 8 percent charge according to the dell battery meter and other meters. However, it takes hours on end to charge that far and depeletes in minutes. When i press the battery test on the bottom of the battery i get all 5 lights which means 100% charge if im correct. The bios is up to date and the power setting is set to power save. Im not sure whats wrong with it and dell charing over 100 for a battery is overpriced so id like to fix it rather then buy a new one. Thank you!
Burf says: Apr 27, 2010. 12:54 PM
Not to put to fine a point on it, but I'd say your battery is about to kick the bucket, sleep with the fishes, push up daisies and meet its maker.
Rather than pay the OEM prices though, check out compatible replacement batteries from after-market manufacturers. You should be able to find a perfectly adequate replacement for $30-$40 with no trouble.
Put the make and model of your laptop along with the word battery in a Google search and you'll get plenty of hits.
One small tip, if everything else is equal go for the highest Mah.  The higher the Mah, the more gas in the tank.
zack247 says: May 1, 2010. 1:24 PM
lots of dell batteries do this. dell didn't make very good batteries for their laptops. all dells made before 2005 have this problem for sure. sounds like you'll need a replacement. check ebay or dealextreme, i ordered one there
virtualgadget says: Apr 29, 2010. 5:54 AM
Batteries get memory where by if they are repeatedly left under or over charged it looses its ability to keep the charge (power) and eventually the chemicals in them (for lack of a more accurate simple term) wear out.
From the sounds of it you battery has come to the end of its life, time for a new one.
trf (author) says: Apr 28, 2010. 7:09 AM
Thank you very much everyone. I am going to get a new battery with a high mah! Cheers guys!
jtobako says: Apr 27, 2010. 6:26 PM
Lithium ion batteries are complicated-there's a chip inside that will resist charging if one or more of the internal cells is bad so that the whole thing doesn't overheat and explode or burn.
___ says: Apr 27, 2010. 6:07 PM
   The sad truth is that batteries don't last forever.  Dell (as well as almost every other large company) completely and utterly rips you off.  If I were you I would buy it off of another reliable seller.
jeff-o says: Apr 27, 2010. 1:18 PM
Your battery is toast.  Time for a new one!  Check eBay for good deals on replacements.  Go for a seller with a good rating.
steveastrouk says: Apr 27, 2010. 11:24 AM
How old is the battery ?
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
