What is wrong with this vbs script?
It is a program to add or remove printers on a local machine, and it works locally, but not when trying to run through group policy in the AD.  Btw, this is a friend's, not mine, so I can only answer so many questions.  Please help.
Here is the code:
PrnName = "Kyocera FS-1100 KX"
Set objWshShell = WScript.CreateObject("WScript.Shell" )
'retrieve username and computername
strComputer = objWshShell.ExpandEnvironmentStrings("%COMPUTERNAME%" )
strUserName = objWshShell.ExpandEnvironmentStrings("%username%" )
strHome = objWshShell.ExpandEnvironmentStrings("%HOMEPATH%" )
strDrive = objWshShell.ExpandEnvironmentStrings("%HOMEDRIVE%" )
Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2" )
objWMIService.Security_.Privileges.AddAsString "SeLoadDriverPrivilege", True
Set colInstalledPrinters = objWMIService.ExecQuery("Select * from Win32_Printer" )
Set dr = objWMIService.ExecQuery("Select * from Win32_Printer where DeviceID = 'Kyocera FS-1100 KX'" )
Set fs = CreateObject("Scripting.FileSystemObject" )
folder = strDrive & strHome
if fs.FolderExists(folder) and dr.Count <> 0 then
For Each objPrinter in colInstalledPrinters
if objPrinter.DeviceID = PrnName then
objPrinter.SetDefaultPrinter()
end if
Next
else
'if fs.FolderExists(folder) and dr.Count = 0 then
'For Each objPrinter in colInstalledPrinters
'objPrinter.Delete_
'Next
'end if
if (fs.FolderExists(folder)) and (dr.Count = 0 or colInstalledPrinters.Count = 0) then
' Add a l'imprimante
Set objPrinter = objWMIService.Get("Win32_Printer" ).SpawnInstance_
objPrinter.DriverName = PrnName
objPrinter.PortName = "USB001"
objPrinter.Location = "Imprimante installée sur la machine " & strComputer
objPrinter.Comment = "Imprimante " & PrnName
objPrinter.Network = False
objPrinter.Put_
end if
if objPrinter.DeviceID = "Microsoft XPS Document Writer" or objPrinter.DeviceID = "PDF4U Adobe Creator" or objPrinter.DeviceID = "Microsoft Office Document Image Writer" then
objPrinter.Delete_
end if
Next
' restart spooler
Set objSpoolerSvc = objWMIService.Get("Win32_Service.Name='spooler'" )
iReturn = objSpoolerSvc.StopService()
iReturn = objSpoolerSvc.StartService()
wscript.quit
end if
'For Each User In objlocal
'If lcase(User.Name) = lcase(strUserName) Then
'Set objUser = GetObject("WinNT://" & strComputer & "/username, " & strUserName)
'msgbox User.Name & " already exists." & vbCrLf & "The password was re-set."
'WScript.Quit
'End If
'Next
'End Sub
'strCommand = "rundll32 printui.dll,PrintUIEntry /y /n Kyocera FS-1100 KX /f /r USB001"
'intResult = objWshShell.run ("rundll32 printui.dll,PrintUIEntry /p /n Kyocera FS-1100 KX" , 0, true)
mwrenfro7 years ago
If your friend has the authority to do so, I'd immediately look at installing Group Policy Preferences. Preferences can be applied to systems running XP (with a client-side extension installed) or higher (no extra client-side parts required), and preferences can be managed on systems running Vista, Server 2008, or higher.
One introduction to configuring printers with GPP is here.
geekvig (author)  mwrenfro7 years ago
I asked him about it, but he hasn't gotten back yet.  He should have the authority to do so, but I'm not sure.  I also don't know what OS he has, but I think it's XP.  He lives in another country, so I don't have access to his machines or anything like that.
