What kind of SCR would I need for a coilgun with 2500uf 500vdc capacitors?
Using a bank of 6 capacitors, all rated for 500 WVDC and 2500 uF. I'm only going to be mainly using them with 240 and 130 VDC. Would a 500Amp SCR be applicable?
iceng4 years ago
Here is a Hockey Puck SCR that will be the most powerful No-Fail device
in your experimenting arsenal for a weapon.
The one pointed to here is a 400A and 1200V SCR at $30..
You can also get one like the picture 1500A and 6500V SCR at $100..
There is a kicker when using this style of SCR which must be squeze
tightened between parallel isolated heatsinks in order to conduct !
And Don't Stand Behind Me !!
Mudbud (author)  iceng4 years ago
Just got a 1000A SCR, roughly calculated coil resistance and this should work dandy :)
Thanks.
Work out your coil resistance, and then you can work out the peak current.
+1
at zero resistance, (mostly impossible) even a small cap would output near infinite current for an infinitesimal amount of time. It's based on coil draw not the cap.
