What kind of clutch can I use on a Home-built motorized bike?
I'm converting an old mountain bike into a motorized dirt bike kind of thing using a small lawnmower engine. I want to know how to make a clutch that is simple and efficient.  Also I'm curious as to what kind of throttle will work on a lawn mower engine?
centrifigul clutch would be the best option, assuming you know what your doing and are not just trying to "redneck" something to ride around. However, if a centrifigul clutch is too expensive, try a a v-belt, and use a jackshaft to convert it to chain drive for your rear wheel. allow the v-belt to slip, and then use a tensioner pulley to tighten the belt when you want to put it in gear.
zilcho (author)  the mechanical engineer6 years ago
I found some replacement clutch pads on ebay that worked on the lawnmower engine's centrifugal clutch. Also bought a dirt bike handle bar throttle but havent gotten a chance to see if it works yet.
2hot2hack6 years ago
just as he said
caarntedd6 years ago
Centrifugal clutch. Twist throttle control, just like a motorcycle.
