What kind of lense do I need to see infrared with my eyes?
I want to take pictures and see inrared with my eyes through a lense or filter of some sort.
What kind of filter do you recomend?
Can I see IR with a IR filter? (def. of a filter: blocks certain wavelenghts of light).
Thanks
11
answers
Answer it!
You need a camera that will detect IR and convert it to visible wavelengths.
I believe some types of night vision goggle do this.
Here's an old paper where human IR sensitivity is measured from 400nM out to 1000nM
Sensitivity of human eye to infra-red radiation
JOSA, Vol. 37, Issue 7, pp. 546-553 (1947)
http://www.opticsinfobase.org/abstract.cfm?URI=josa-37-7-546
A diagram from the above paper, semi-log graph
http://amasci.com/graphics/IRcurve_HVS.jpg
Note that the sensitivity decreases smoothly, with no division between "visible" and "IR." Vision at 1000nM is almost 13 log units down from the green sensitivity peak at ~550nM
You can see IR in the camera view screen.
This is a great community.
I liked all the different answers!
All the best to you!
There is FILTER that can convert IR to something visible. There is an instructable on how to make goggles that filters 99% of visible light and all you're left with is very very low red, and 'infrared' - which you still cannot see.
To truly see infrared you need something like an IR camera (or one modified to take IR photos) then look at the picture/video coming from that sensor.
Because of the way our classification works, most people will use the term "infrared" for wavelengths of light bigger than 700 nm.
Because of the way your vision works, there is no hard cut-off point between "visible wavelengths" and "invisible wavelengths" of light. Rather, your retinal pigments have a wavelength at which they work best and rapidly lose sensitivity as you move away from this point.
So it may be possible to see a tiny bit into the range usually classified as infrared by making this light very very intense and blocking out all other light. This is what the Infrared Goggles project attempts to do.
However, it only works as advertised when everything is lit by a very powerful source of near-infrared (such as the Sun). It may help you notice things you would ordinarily overlook. But it absolutely will not give you night vision or enable your eyes to receive any light that they don't normally receive.
http://www.instructables.com/id/Homemade-Infrared-Goggles!-For-Under-$10/
There are instructions for swapping out the IR-blocking filter for one that passes only IR light. You need a digital camera or two that you don't mind accidentally destroying.
http://www.instructables.com/id/infrared-digital-camera---the-real-way/
IR LEDs can make a good "invisible" flood light for short distances, 3 or 4 meters, to watch things or take pictures with, and animals (people too) cant see it....
With other tools? Many digital cameras can see at least some IR bands. There have been instructables about ways to take advantage of that via a filter that blocks most visible light. If you already have a camera on hand, that's worth trying.
L
