loading
What kinds of machines/tools are used to mass produce BULLETIN BOARDS mostly CORK used.
Want to manufacture BULLETIN BOARDS
Mostly using CORK.
Any guidance
Thanks
Burf7 years ago
Generally, industrial carpentry tools, cork is, after all, just wood. But, more specifically, it depends on the frame you intend to mount the cork in; aluminum, steel, plastic or wood. Also whether or not you plan to do your own extrusion, bending, injection or vacuum forming is a factor, as each requires more specialized tools than used for  simple wooden frames.
abcofficesupply (author)  Burf1 year ago
Thank you
lemonie7 years ago
I'd say "cutters" mainly. There's probably some manual assembly with glue / a staple-gun?
L
abcofficesupply (author)  lemonie1 year ago
Thank you
You can contact a factory that's already producing cork boards and put in an order according to your specifications.
You can contact a machine shop that is capable of making a machine that will meet your needs.
You can order all the products and set up your own factory and do it all essentially by hand.
However, it's unwise to invest a lot of capital into something that others are already doing, so it's wisest to contact a factory that's already making cork boards and place an order unless you have a radical new design that will change the face of cork boards as we know it.
abcofficesupply (author)  AngryRedhead1 year ago
Thank you
