What needs to be considered before buying a wood lathe?
I am thinking of investing on a wood lathe. I have seen a few lathes of different sizes. I would like to turn bowls, dishes, chalice and even mortars out of wood. What should I need to look for on a lathe? It is size important? Thank you very much once again! You are the best!
Feb 19, 2013. 2:40 PMsteveastrouk says:
Most times, it seems to me, maximum turning diameter matters most, thence motor capacity.
Feb 20, 2013. 3:29 AMsteveastrouk says:
Yes, you don't seem to have a yen to make stair spindles or lamp standards ! I've seen some MONSTROUS bowl turning lathes, that'd have your hands off if you approached the work wrong.
Feb 20, 2013. 7:28 PMRe-design says:
I've seen that lathe and don't consider adiquate. the rails are made fo hollow tubing and will flex during use.
I bought this one because it's gear box was stronger and has cast iron rails that won't flex.
Feb 20, 2013. 6:43 AMrimar2000 says:
IMHO, the power of the motor is a capital matter. Then, length and diameter must fit your needs.
Feb 19, 2013. 2:23 PMiceng says:
First a compressor, now a lathe for wood ?
Even with a Big size lathe, you cannot make wood or plastic
survive as a pressure tank.
Only good thing is it it will float ( teak is no longer available :-)
A
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
