What should I do with this tripod I found?
So a couple weeks ago, I found a camera tripod with telescoping legs in somebody's garbage. It doesn't fit my camera, but there is essentially nothing wrong with it. So basically I need some ideas for what I should use said tripod for.
Burf7 years ago
Mount a small piece of plywood on top and use it as a stand up or sit down laptop stand.
Add a couple of brackets to two legs and use it for a child's easel.
Mount a flood light to the camera mount and use is as an adjustable spotlight.
stronglad (author)  Burf7 years ago
I'll give you 2 for three because I don't have any kids hahaha.
Kiteman7 years ago
Drill a hole through the top plate, and thread a quarter-inch bolt through so that is projects about quarter of an inch - the bolt will screw into the standard-thread socket in the base-plate of most cameras.
orksecurity7 years ago
I used one to mount a directional WiFi antenna, a few years ago -- easiest way to hold the cantenna in the proper orientation was to bolt a piece of PC board to the tripod and then strap the cantenna to that. Looked a bit MacGuyver, but it did the job. (I was setting up a data link from one end of a hotel to the other; for annoying technical reasons we couldn't use the hotel's network.)
Or use it as a mount for a small telescope. Or for a microphone. Or rig it for use as a music stand, or maybe an instrument stand.
caarntedd7 years ago
Sell it.
AndyGadget7 years ago
If it's a decent tripod it's probably worth finding the right adaptor to make it fit your camera.  Some manufacturers use their own fittings - Does it have a brand name?
My tripod has a quick-release lever mechanism which needs an adaptor plate screwed into the normal tripod thread of the camera. Have a browse around the online photo-stores or post a picture of the top and someone should be able to ID it.
(Alternatively, take off one of the legs and you'll have a bi-pod and a mono-pod which also don't fit your camera ;¬)
lemonie7 years ago
Get a fresnel-lens and make a solar death-ray.
E.g. http://scitoys.com/scitoys/scitoys/light/marshmallows/solar_roaster.html
L
Re-design7 years ago
Make an adapter for your camera.
Make it into a lamp base.
Get an OLD camera and display it on the tripod.
Give it to a friend who needs a tripod.  (Good karma)
stronglad (author)  Re-design7 years ago
Well it looks like I don't have any friends who need a tripod, but I like the lamp base idea.
