What's The Best Way to Organize Nuts / Bolts / Washers / Fastners?
I have a dedicated 14 drawer tool box with 41" W X 20"D X 2"H drawers in which I now just throw all of the fasterners of a given type, size or material in a zip lock bag. When I need something I have always have to open all the drawers to "maybe" find what I'm sure I already have.
I know drawer dividers and lables are part of the solution but I'm not sure how best to make them nor how to "lay out" the various sizes, materials etc...
Maybe you have had this problem and solved it. All suggestions are welcome & thanks in advance.
8
answers
Answer it!
Typically that means dividing first by general type (screws versus bolts/nuts versus nails), then by thickness, then by thread (so bolts and nuts which fit each other are grouped near each other), then by length, then by head (slot/phillips/hex/whatever). Washers should probably be sized first by ID, then by OD, and grouped with the bolts and nuts which are the closest fit.
That's the _best_ way. For most of us with smaller storage than your toolbox. we break off somewhere before the bottom of that chain is concerned. I have some things sorted out exactly, when they're sizes I tend to use frequently; others may share a bit (preferably in a way that still allows me to tell them apart, but I do have a few "pi bins" of intermixed hardware that either hasn't been sorted or that I don't expect to have enough of to make complete sorting worthwhile.
. Screws and bolts sorted by diameter. Sub-divided by pitch, if needed.Sub-sub-divided by length, if needed. sub by grade, if needed.
. Nuts by diameter. Sub-divide by pitch, if needed.
. Washers by ID. Sub by OD, if needed. Sub by type (flat, star, &c), if needed.
. YMMV
And get some labels for the outside of the drawers.
Make some dividers for the inside of the drawers. Maybe just divide the drawers into quarters.
Patrick
Check these out for great ideas.
http://www.instructables.com/id/Custom-Fitting-Drawer-Organization-Boxes/
http://www.instructables.com/id/Make_Cheap_Easy_Cardboard_Small_Parts_Storage_Org/
Patrick
