3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
What's the best procedure for making salicylic acid?
Is it possible to make salicylic acid from aspirin using pretty common household gear?
If not, what would be the procedure for deriving it from willow? and what kind of willow to use?
Would it be more cost effective to buy crystalline salicylic acid?
Bonus Question:  What ppm would be good for using it as a facial cleanser and an anti-dandruff shampoo? or rather, what ppm would be bad?
If it matters, I've done a year of chemistry and a year of organic chemistry with labs.  I sucked at the classes but rocked the labs like KISS at an assisted-living activity day.
Dec 30, 2009. 1:31 PMmakendo says:
Yes, buying it is greener: ASA is made from SA anyway, so if you were to extract ASA from aspirin, then hydrolyze it to SA, you've wasted a lot of reagents and solvents for nothing. Good info for your app here:
personalformulator.com/wvss/product_info.php
Feb 10, 2011. 8:07 AMrncbme says:
Salicylic acid is the main ingredient in "Bar Keeper's Friend" and also most wood bleaches (Lowes, Home Depot, etc). It is obtainable in much larger quantities than what most people would think about making w/aspirin.
Dec 30, 2009. 10:36 AMlemonie says:
It's not going to be hard to obtain from Aspirin - but you've got the product to purify afterwards. Possible yes, but if you can buy it that would be easier.
The skin-destroying formulations for wart-removal are ~ 10% w/v, so you'd want much less than that or a short exposure.
DIY acid-peel?
L
Dec 30, 2009. 2:06 PMlemonie says:
It's a pretty-strong phenolic acid, but I didn't know it was in those things. Start it below 0.01% w/v and knock it up an order of magnitude at a time if you don't think it's enough?
L
Dec 30, 2009. 2:41 PMlemonie says:
Bi-carb' rather than peroxide I think. I didn't know the 'poo was that much, but I'm learning here...
L
Dec 30, 2009. 10:33 AMBurf says:
http://www.crscientific.com/article-aspirin.html
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
