3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
What's the best way to make burn marks on clothing?
I'm putting together a pirate costume for a Renaissance Faire, and I was wanting to make some realistic looking burn marks on it, like bullet holes, fire damage, etc. Any suggestions?
Jun 29, 2010. 2:23 PMGorfram says:
I'd do both fire and controlled heat:
- Fire (using appropirate(sic :) precautions) on some scraps of the fabric you're using, so that you'll have a "model" of real fire damage to work from. If you know someone who does target shooting, ask them to shoot a fabric sample or two. If not, I'd suggest cutting a hole in the fabric sample and the holding it with the hole centered over a candle flame.
- Controlled heat (from a clothes iron, sautering iron, electric hot plate, etc.) plus black & brown fabric marker for the real costume you're going to wear. Fire damage causes, well, damage to the fibers of the fabric, and the last thing you want is for your costume to fall apart the first week of Faire.
If you use plug-in electrical appliances and can plug them into GFI outlets, you'll be that much safer.
Also, remember that natural fibers burn, but synthetics melt - not such a Renaissance look :)
Good luck with your costume.
Jul 2, 2010. 12:35 AMGorfram says:
Thanks for giving me Best Answer, and have fun at Faire! :)
Jun 29, 2010. 12:04 PMRe-design says:
Matches or a lighter. Do it leaning over a bathtub filled with water so you can stop the burning when you want.
You might highlight the burns by mixing black and brown artists acrylic paint and touching it up.
Here's a great pirate bandanna shape and tying link .  that I found yesterday.
Jun 29, 2010. 1:12 PMJohnJY says:
Fire.
Jun 30, 2010. 3:11 AMcaarntedd says:
+1. Fire always makes it better.
Jun 29, 2010. 1:30 PMlemonie says:
Heat needs to be controlled, a "hot thing" may be better for you than a flame. I.e. heat a metal-stick. Otherwise go with Re' and a blow-lamp.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
