When an electric range or oven element erupts(?), what is going on?
While trying to boil water today, there was a bit of flame briefly visible under the stainless steel kettle. Picking it up, it looked like a wet squished bug on the burner (actually bubbled metal or ceramic) ... and a slow leak in the kettle from a small burned spot. This seemed very contained. Many years ago when the oven element blew out it spewed white powder and tiny silver blobs all over the oven. So what is happening in the element when this occurs? (I don't really know what 'calrod' is made of.)
5
answers
Answer it!
Movie theater projectors used to use this process to create the extremely bright light for projection. Its called a carbon arc light. Carbon rods are touched together, then a current is run through them and then they are slowly pulled apart. The power jumps the gap and the arcing process begins and makes an extremely bright light. The rods are kept at the correct distance by a feed mechanism as the rods are slowly consumed by the process.
http://www.partnersinrhyme.com/soundfx/electric_sounds/electric_e-arcing_wav.shtml
