Where can I find out if a limited range, electronic jammer is legel in my area?
15
answers
Answer it!
listening in phone calls = make random calls to known telemarketer numbers, then use a tone generator to send the highest possible ear-destroying triangle tones at unbelievable decibels - randomly :D Same with skype.
if they're using a telescope, a VERY VERY BRIGHT LIGHT used intermittently comes to mind.
I suppose in the short term you could use pink noise masking, if it makes you feel better. Open "pink.exe" from the "release" folder of this. But remember that this does not fix the real problem: that you are unhappy with your neighbor's behavior.
If they have planted an actual listening device on your property - including embedded in the wall between your properties - then they will have at least invaded your privacy to the point where you can pursue a civil case for compensation, probably even a criminal offence. However, you must have actual evidence - you have found a listening device on your property, or your neighbour must have commented or acted upon something you have said in a situation where they could not reasonably have overheard you (and they must have made the comment or performed the action in front of a witness).
Without the evidence, you are on a losing streak. If you think they are listening in with microphones, then audio interference is the route to take - loud music, "ambient" noise (whale song etc) or "white" noise, like running water or radio static.
However, you then run the risk of "causing nuisance" to other neighbours, which would get you in trouble with the authorities.
If you think he is listening in electronically, then you have problems, as radio jammers are almost universally illegal, except in the hands of the military or law enforcement.
If you are convinced your neighbour is actively listening in to your life in any way, and is deliberately causing you distress as a result, but are unfortunate enough to have no evidence, then you may instead find it useful to approach a lawyer of some description and ask them to draft a letter (on the lawyer's own headed paper) saying, in suitably-intimidating lawyer-speak, I know what you are doing, back off or else.
