3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Where can I find white plastic sheeting?
Black or clear will not work, and that's all I can seem to come up with on google. White and black on opposite sides could work, but I can't find the size I need. Speaking of size, I need it to be 16 to 20 feet wide (and similar length, but rolls could be longer); most seem to be 100' for sizes that wide. One other requirement- reinforced sheeting will not work, I will need it to have a smooth surface when I'm done. Thickness matters less, but obviously the thicker the more expensive and I think 4 mL would work fine. What's it for you ask? Sorry, but it's a secret, at least for now.
Jun 15, 2009. 7:36 PMkelseymh says:
Try "vinyl sheet" instead of "plastic sheet".
Jun 16, 2009. 11:02 AMfrollard says:
You'll have a real hard time finding vinyl wider than 48 or 60 inch wide - but it would work...just need to seam several together.
Jun 16, 2009. 4:50 PMfrollard says:
...and properly connected vinyl sheet is almost indistinguishable when its welded chemically.
Jun 16, 2009. 4:47 PMfrollard says:
did you check out my other link?
Jun 16, 2009. 11:04 AMfrollard says:
The plastic in black and clear is 'polyethylene'.
Search for 'white polyethylene sheet' and I found a bunch...notably:
http://www.plasticdepotofburbank.com/whitepoly.htm
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
