Where can I get a laser and a sensor? (preferably cheap)
I'm looking for a laser that is button activated and a sensor that reacts to the laser.
Basicly I want to put the laser in the barrel of a broken bb gun and make the button so that when you pull the trigger the laser goes off. Then I want to make a circle with the sensor in the center and when you hit it with the laser you hear a sound.
Now I am wondering where I can get a laser and a sensor that responds to it. the laser can be visible or invisible I don't really care. Also does the sensor respond to any laserbeam or is this specific?
Thanks in advance,
Michel
answers
Answer it!
Look at the 2nd circuit down HERE - You'd replace the switch with the photo-diode and may have to increase the top 47K resistor value. (You could use a 556 which is 2 x 555 in the same 'box'.)
If you don't have 555/556 timers you can make an astable with NAND gates / transistors /op amps and a whole heap of other things and you can create time delays with resistors and capacitors too.
