Where do you get potassium nitrate?
15
answers
Answer it!
I USE IT IN SMOKE BOMBS AND OTHER AMATEUR PYRO STUFF
YOU CAN GET IT A LOWES HOME IMPROVMENT STORE APPOX $ 4.00 PER BOTTLE 16 -24 OZ
a word of warning, i have bought stump remover potassium nitrate, and used it, and everything barely worked as expected, i thought it was because of my own mistakes, however, i bought some pyrograde potassium nitrate, off ebay, and the stuff works a treat, everything works, i can even make fuses just with cotton string and dextrin!
the grade in stump remover is generally high in contaminants and stabilizers, or stabilized potassium nitrate, that wont readily decompose the way it should.
its useless for rockets, gun powder, smoke bombs (if you dont want to make one that is more than 800g), and all slow burning or incendary mixtures, though it does burn rather weill with aluminium powder and zinc powder.
basically useless unless your burning it at a tempurature than would normally vapourize it like steam.
my advice is to not use nitrate for rocket engines, and go use some potassium perchlorate instead, which is used in the main ingredient in commercial rocket engines (well all that ive ever been able to buy anyway, i cant vouch for other brands)
its easy enough to make, but be sure to not use chlorate, as that is far too unstable and will explode if mixed with sulfur, or burnt with sugar, if not done properly
Thank You
1) It's available someplaces as fertilizer, usually in 50lb bags. "K-power" or similar brands; straight KNO3 with not much else. Hydroponics grade is the easiest to use. If course, admitting to doing hydroponics might get the drug enforcement folks on you faster than the BATF would ever show up if they thought you were making rocket engines.
2) Several brands of "Stump remover" are pretty pure KNO3 prills. Sold in 1lb boxes or jars.
3) Ceramics dealers seem to repackage the fertilizer grade stuff as a glaze ingredient. If you have a ceramics dealer that sells glaze ingredients...
4) Some drug stores and feed stores may still be selling KNO3 as an animal diruretic.
5) Asian markets may be selling KNO3 as a component for "pickling salt"
