Where to buy MURIATIC ACID & PEROXID in UK ??? What kind of shop ???
Hi ... where can I buy MURIATIC ACID (HCL, hydrogen chloride) and PEROXID in UK ??? What kind of shop should I go and ask for it ??? Is there an different name for the muriatic acid in UK English ???
And what about peroxid ??? In a chemist's / drug store ???
Thank you for your advice...
Zholy
Jun 21, 2010. 3:10 PMLinemenOwn says:
Muriatic Acid is commonly found in pool supply stores. It is used to adjust pH of the water. Hydrogen Peroxide is found in chemist or drug stores. Once you have them mix them 2 parts peroxide to 1 part Muriatic Acid.
May 31, 2010. 4:12 AMlemonie says:
Rather than ask about what you want, what do you want to do?
These things come in different concentrations, that affects the "where"
L
Jun 1, 2010. 11:15 AMlemonie says:
Thanks for the information, you see Steve' seems to know what your problem is.
L
May 31, 2010. 5:03 AMsteveastrouk says:
H2O2 for etchant  from a hair dressers supply.
HCL from a good builders merchants as "brick cleaner"
Changing to the cupric chloride etch won't fix the pits - that caused by poor resist.
If you possibly can, switch to a photoresist
May 31, 2010. 6:30 AMsteveastrouk says:
Hi Zholy, the resist is the substance stopping your tracks from etching - the laser toner transfer method in your case.
Are you in the UK now ?
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
