Where would I purchase a drill bit to mill out PCB for the dremel tool for my CNC Machine?
I am Buliding Tom McWire's CNC machine and I plan to use it mainly for Milling PCBs. Prices-Sources-alternatives please
Putzer8 years ago
drillbitcity.com
alexrain2167 years ago
Hello
This is Alex writing from Wonderful PCB(H.K) Limited.
Wonderful pcb ltd,is a professional engaged in production of high-quality technical content required strict cell phone board,all kinds of double-sided, multi-layer, multi-layer buried blind hole, aluminum panels, printed circuit board, single-sided multi-layer soft board manufacturer.
Factory production since 1996 has been well recived by customers all over the support and trust, continue to steadily increase production of a monthly capacity of hard-board PCB to 20000m2/month, single-sided multi-layer soft board(fpc) 3000m2/month. Product quality standards and the reference to IPC U.S. military MIL standards,and passed ISO 9001 quality assurance system, UL safety certification and ISO14001 environmental certification system for quality assurance and other ways to provide you with safe and reliable products.
You early reply will be highly appreciated.
Best regards
     Alex
Wonderful PCB(H.K)Ltd
Tel:+86 0755 86227586 ext.812
Fax: +86 0755 26073529
Skype: alexrain216
ICQ#:561159768
Email: wonderful04
@wonderfulpcb.com
Website: www.wonderfulpcb.com
             http://wonderfulpcb.en.alibaba.com/
Add: NanShan District,ShenZhen City, China
Visit the nearest store that sells powertools and examine their selection. If they keep a decent stock of bits and accessories, they'll have everything you need.
I've never found a local store with drill bits small enough to do pcb holes...smallest I could find were larger than the pads themselves :(
Check your local hobby shop (one that deals in high end trains and airplane models).
DUH!  Why didn't I think of that!  Thanks!
seandogue8 years ago
yep, what Putzer said. You want "contour router bits" for cutouts on the PCB (say, for something that might protrude thru the PCB), and router bits for cutting the voids between circuit paths. All the tools should be carbide.
Darn...correction...for the voids you need end-mills, not "router bits". Be careful..small diameter endmills are very fragile and slow traverse speeds along with high spindle speeds MUST be used to reduce endmill failure.
Learnt the hard way on a T-Tech machine several years back
for the least expensive bits, you can often find re-sharpened bits sold in lots on Ebay and elsewhere. The are cast-offs from PCB board houses that are resharped and sold at reduced prices.
16zzundel5 (author) 8 years ago
I need the bits for drilling and spade types for as cheap as possible
Whatever, make sure its Solid Carbide.
