Which NERF Gun is Better? Triple Shot or the Quick 16?
I don't know what to get? I want to get the Triple Shot becuase it shoots three darts at once. Cool, huh? It has a range of 30 ft. after air ristrictors being removed. Not much, but I usually have a war in my house so it's a reasonable range. It's pump action and it's 21.99 at Toys "R" Us. The Quick 16 is cool becuase it has a slam fire mode that means it's fully automatic, semi automatic, and pump action. It has a built in stock and you insert the darts in without taking the clip out. That's what got me excited about this blaster. I don't know exactly which is better. If you have one of those blasters or have used one. Then can you describe the advatages and disadvantages? Thanks!
Picture of Which NERF Gun is Better? Triple Shot or the Quick 16?
username2526 years ago
The Triple Shot seems to have better terms in power and amount of darts shot, but the darts look like they're made for the gun especially. Unless you mod the barrels, it could force you to buy more darts and make others unusable. It's also annoying to scavenge for darts and hold them in makeshift containers. To me, it's not ideal for use, and the size is too big.
The Quick 16 seems to be more versatile in use, like the Raider. Its compact feature derived from the Raider makes it better to reload faster and a chance to control how you shoot and reload. The design to use tagger darts give you better use of the darts you already have. The capacity of darts look to about 10 to 15 darts, which is better than the previous models. Size is good also. Making use of the Velcro equipment, the darts can be better managed.
In terms of costs, the Quick 16 looks more expensive because of the brand. If money is no object to you, go for the Quick 16. I hope that this helps in choosing your gun.
lil larry (author)  username2526 years ago
Thanks, but this is the second time you said this. This is the exactcomment you said about 10 min. ago...
BTW, best answer for me????
I won't do it since your rude! Just kiding, is this a question? OK? It doesn't have a "Best Answer" button
I see it now. Thanks!
Your Welcome!
Weird, i didn't type this...
HACKERS ON THE LOOSE!!! (JK)
Could be a typing glitch, but I I was sure I types something else.
Then what did you type in?
I said that, like the Raider, the gun looks prone to inherit the problem the Raider had: shifting firing distances. Some shots could be true, while some will simply fall a pitiful foot or two. Removing the AR might fix this, but I'll let you mod it your way :)
Yeah! I got the raider, but it was not made for the six dart clips. The drum tat came with it breaks (well, for me). And then when I switched to the regular clips, it's just a peice of junk.
OK! Thanx for telling me! I actually didn't know that the triple shot holds bigger darts! Thanx a lot! I'll get the quick 16!
